good morning. I have obd11 with pro subscription.
is it not possible to have a graphic like the obd ELM 327 reader and App infocar to read the percentage of clogging fap_dpf?
Beiträge von beppecupra
Guten Morgen. Ich habe obd11 mit Pro-Abonnement.
Ist es nicht möglich, Grafiken wie den ELM 327 OBD-Lesegerat und die InfoCar-App zu verwenden, um den Verstopfungsprozentsatz von fap_dpf anzuzeigen?Danke
good morning. is it possible to code the ignition (side lights or dipped beam) when a certain speed is exceeded?
sorry I inserted double license plate light screenshots. original parameters
Thanks so much for the clarification.
what cause is that not allowed this encoding? reason?
other people went well successful coding 24?
Good morning. I tried encoding 24 on page 13.
1) I would like to know which license plate light is.
" leuchte 25 kzl has 59, or the leuchte 23 sl hl c10?
2) during coding the error "31 function not available" appears
car with electric trunk
1) I would like to know which light is from the "leuchte 25 kzl ha 59" plate, or the leuchte 23 sl hl c10?
Buongiorno. Si prega di fornire una codifica 24 a pagina 13.
1) Vorrei sapere quale luce proviene dalla piastra "leuchte 25 kzl ha 59" oppure dall'apparecchio 23 sl hl c10?
2) durante la codifica confrontare l'errore "31 functionzione non disponibile".
auto con portellone elettrico
https://Formentor-forum.de/attachment/10972-screenshot-20231014-112937-youtube-jpg/
good morning, are there any updates or new features? Has the encoding for the last S&S status memory been found? or the only external module mounting solution. Thank you
Speravo... di migliorare l'effetto turbo lag.
soluzioni? Mappatura ECU o modulo aggiuntivo?
Funziona, ma influenza la ricarica della batteria. Nella mia macchina era carico al 50%. Il valore predefinito è pari al 75%. Misurato con un tester cinese economico.
buongiorno, anche altri hanno avuto problemi con la ricarica della batteria?
Sto usando la codifica stg19, unità di controllo della batteria. il s&s è sempre disattivato, non ci sono errori di infotainment. (Ho un dubbio se lascio l'auto parcheggiata per qualche giorno se si verifica un errore. )
Voglio controllare di nuovo con l'OBD se la ricarica è corretta con il motore acceso.
throttle pedal response:
Buongiorno. chi ha provato questa attivazione? (app obd11 con un clic).
Non l'ho visto nell'elenco 1.4.0?
Grazie
Arrivederci. Qualcun altro oltre a CanbiZ ha il punto “51. Hai provato il tono di conferma tramite avvisatore acustico e lampeggiante (senza DWA)?
Con quella persona ha funzionato senza problemi oppure c'era ancora qualcosa da aggiustare?
salve, ho anche provato a codificare 51 (pdf 1.4.0 ultima versione) ma non funziona per me. Ho la configurazione XL.
Mi sembra che siamo più persone che ci provano ma con risultati negativi. forse andrebbe eliminato dalla lista..
